have got bearing noise when machine is on spin cycle. can there be any way to grease it or if it needs replacing can anyone give me information on how to do it cheers jimcas
3 dif types for this mc welded tank ,its a complete write off, if its a back place on the drum it has to come off ,or it can be a spider bolted on the back can u post pic of the drum.
it that case its a 4 legged spider .rear pully bolt comes off you need a torx 40 bit ,then pull off belt and pulley ,in each corner of the spider is 2 bolts undo them 8 bolts in total ,then pull spider off and drift /whack bearings out then replace bearings and refit in reverse order .do not strip the pully bolt head hit it first to break the nut lock otherwise new drum needed.
