- Joined
- 7 Jul 2006
- Messages
- 94
- Reaction score
- 0
- Country
Hi, I came this washing machine which does not drain the water, after cheching all the possible problem I found that the pump OK and when the supply leads off the pump it does read 240V but once I plug the leads back in to the pump the reading is 0V but the live is there, the problem started when the MCB tripped off at the fuse box at the time the machine was on, when they put the MCB back on this happened, to be sure I did change the pump but no change, any idea
