- Joined
- 27 Sep 2022
- Messages
- 300
- Reaction score
- 23
- Country
I have a Viessmann vitodens 100-w (compact 13kw) boiler installed in OV configuration (2 pipe system) for CH only. It has a drayton (LP722) timer and a dial type Room Stat. My CH load is under 7 -8 kw.
This year I have bought a Weather compensation sensor and cable which is straightforward process for installation for central heating only.
I am in the process of adding a hot water cylinder to the same boiler and I have bought a 120 litre indirect water cylinder.
I have a 3 port (mid position valve with A & B outlets for CH & Bath) which will be fed by an external pump installed on flow out of the boiler.
I also have a wiring center which can be wired for various configurations; S,W,Y,X or PDHW.
I intend to heat the cylinder once in the morning and in evening.
Stuff I need to buy include a cylinder thermostat, a PRV/Temp valve
Questions
Can I install an open vent DHW or do you reckon that I go for unvented system with an EV?
Which configuration should I go for? I have read that Y or S plan are outdated and PDHW should be installed. I am not sure if I can have PDHW on two pipe system?
Do I need a separate pump for domestic hot water apart from CH pump or separate port actuator (the ones you require for an S Plan)
To run weather compensation, do I require a cylinder demand terminal box from Viessmann? Is it necessary to get one as it is quite expensive.
What other components do I need to install cylinder?
Any advice is welcome, I have plenty of time before next winters so I want to do my homework.
Thanks in advance. I installed OV CH system last year with a lot of guidance from this forum.
Questions
