Indisit washer-dryer door seal help
24 Dec 2015
Hi
I tore the door seal on an Indisit IWDE 126 intergrated washing machine and dryer. Can't use it as it purse water out!
Ordered a replacement door seal and I have successfully got the front of the door seal off.
However I can not see how to get the seal off from around the air inlet bit of the door seal.
The washing machine is built in so I can't get front of the machine off so going in through the door.
Have only found two videos for washer dryer door seals and neither seem to be the same.
Can anyone help with instructions of how to get the seal off the air inlet?
Thanks!
Oh, looks/feels like it is held on by a black plastic band but no idea how to get that off.
On fitter investigation that is zip tie band which needs to be pulled off, and a new zip tie is needed when fitting the new seal.
I can't pull it off so think I'll call in an expert!
Cut it off. Replace with a cable tie
