'Industrial' Steel Conduit
4 Feb 2006
Sussex
Please can anyone point me to a good supplier of 'Industrial' looking galvanised steel electrical conduit. I want to install a new lamp in my kitchen.
Any electrical wholesaler will be able to supply it.
Do you have access to the tools required to work with it?
adam_151 means a conduit bender
(£570 inc vat for this one)
stock and di set (£28 for this one)
cutting compound (£9)
(£14 for a 3.7 M length)
+ what ever fittings you need
Total £621
do you still want it?
all prices taken from various websites, other suppliers of this equipment are available
not shown but also required are hacksaw and suitable grips and file and cup of tea
Vice and bender as above isnt really necessary, years before vice and benders became popular skilled sparks could with practice use blocks of wood with drilled holes in them to pipe bend and curves could also be done with care just by standing on the tube and gradually putting a bend into it.
Of course care and skill had to be used otherwise you'd just end up with a flattened bend :)
So you could possibly get away with spending the £570 it may take a few practice bends to get it right just don't work on the same bit too much.
good luck
good luck
It took me years to master the block pipe bender and about 30mins to master a pipe bender....IMO hire the pipe bender.
PS..before lawn mowers, I think they used sythes :LOL:
Our local wholesaler has a pipe bender which they will hire out to contractors who do not own one.
We have gotten away with using plumbers pipe benders when we don't have access to one. It helps that I work along side a plumber some time so I just borrow his. Never had an issue doing 22mm 25mm galv etc. I have my own set of stock, tap and dies and all ways have cutting compound. Might be an option if you know a plumber.
Adam
Hello,
A combination of 'cheap' kit, and a lack of cutting compound ??. :eek: :LOL: .
Yes, two sets !!!! :confused:
Ed
Sure you want Galv Conduit in your kitchen?! :confused: Ah, just thought, maybe its a commercial kitchen?? :)
Stainless conduit is better in a commercial kitchen.....grease, steam etc can easily kill even galvanised in a fairly short time.
Stainless is rare, difficult to obtain and a PITA to thread!
do these dies stocks and dies you guys use not have the slit and the three pre drilled blind holes that allow grub screws to open and close the die to allow a rough cutting and finishing grade.
That is what we always did as mechanical engineers, although I guess you are not after finess like we were, and just want them to stick together somehow.
Also, make every effort to break the swarf, so every half turn forward, back the die holder back round a quarter, the chip breaks kick in and remove the swarf, and it lets whatever you are using for cutting compound seep forward and lubricate the cutting heads on the die.
Surely someone doing electrical work in a commercial kitchen, given all the liability and EAWR duty issues etc would be the sort of person who'd know where to get galvanised conduit.... :confused:
Not the ones I have used, they are just a round die with 2 half ovals cut out of the side for the stock to hold it. There is usually a guide on the bottom too.
That is how we were taught to do it as apprentices, plenty of swarfega. Once the thread is deep enough, unscrew the die, pop it on the other way around and finish the thread ;)
I would not reverse the die - if you do you will get a parallel thread and the socket won't tighten. It will run loosly to the end and then 'bell' as it tries to travel off the end of the thread - many then split :D.
Leave the die taper end pointing towards the conduit - that will leave a taper at the end of the thread and the socket will tighten onto it.
