Inglenook fireplace stone lintel
23 Jun 2008
Derby
Hi guys,
I have just bought a 360 year old stone built house in peak district in need a lot of restoration work. It does have two inglenook fireplaces but it is covered up with disgusting 60's surrounds so I have removed the wallpaper and plastering above it to find the original lintels and to my glee they are still there!! One of them are in perfect condition, the other one has a horizontal crack which is about 4-5mm wide nearer to the side (not in the middle) I assume it has been there for years?
The lintels I assume is gritstone (it was painted over with dark brown stuff I hope it can be removed!!!!), it is 12 inches tall and 60 inches wide but I don't know the depth until I have actually removed the fire surrounds. Due to the crack is it safe? After a look on the net most say just ignore it?
Have just opened up the fireplace... I had a look at the chimney... errr it definitely needs lining! anyway I am not sure if the lintel is able to support the weight of the chimney above it and I can see a iron bar running across just behind the lintel from the end to the other end which is surprisely in good condition and I wonder what is for, it is part of the chimney support along with the lintel?
And please point out any potential problems too :)
Please see the photos below to gather what I meant:
View media item 56058 View media item 56059 View media item 56057
Many thanks in advance
