i have just replacd my attic cistern ballcock,float valve
The inlet is a copper 90 degree pipe with a nut that pulls against a circular shoulder ring. I believe it's called a bent tap connector. This pipe goes into the threaded part of the ballcock inlet and the nut tightened, When I took it off there
is no sign of a washer or similar - the joint was 'sealed' only with white tape with the circular shoulder up against the chamfer inside the threaded part.
I removed the original tape and applied new but I cannot get a 100% water tight seal. Can anyone advise whether there should be a washer in this assembly? should I just tighten further (easiest option) apply more tape and retighten or replace with something else.
The tank already has an inline isolation valve so disconnecting is straight forward
Kevin
Kevin
