We live in a converted barn which in winter is difficult to keep warm, 2 main reasons being :
1) It's of exposed King post truss construction so no ceiling as such but lots of volume to heat - 20' interior height max & big rooms.
2) When converting, I used the tri-iso roll insulation which was easy & all the rage at the time - don't rate it myself now though.
The construction from the inside is ceiling boards attached to 8"rafters, tri-iso roll over the top, batten vertically,membrane then battens horizontally then pantiles. What I would like to do is get some more insulation in the gap (8") between the foil tri-iso and the ceiling boards. The correct way would be removing all tiles & battens & shoving kingspan in cavity but that's a big job.
Just thinking (don't laugh) could I hire one of the machines that pump the foam in for cav wall insulation & pump in the foam from various points (ie just lifting up a tile & pushing injector through membrane along the ridgeline of the roof ? It's steep at 43 degrees so should find its way down ! anyone done something similar ?
