Hi, I've got water dripping from the bottom of the Insinkerator. It comes out from the grommet where the power cable comes out of. Does anyone know how to remove the base cover and can I buy the replacement seals?
if you untwist the erator from the sink waste it easier to work on.
look around the edge of the erator it useally has 3 long screws that hold the top part to the bottom.
depending on age of the erator it may not be worth spending money on it as the plates inside rot away.
