Inspection chamber questions. Ultimately, can i move it ?
4 Jan 2007
Hi all, 7 years after my last post I'm back :D
So I have a "chamber" in my drive where I would like to extend to, isn't that nearly always the case.
upload_2017-1-22_13-6-9-png.814861
I had always assumed it was a rodding point for the foul water, the soil stack is internal and runs to the left of the little window you can see above
Popped the cover off the other day and saw this
upload_2017-1-22_13-4-26-png.814860
Not quite what I was expecting to be honest . was expecting to see a gully of some sort I guess.
Flushed the loo, nothing happened . so I have a couple of questions
Is it one of these
upload_2017-1-22_13-42-30-png.814875
If not , what is it, whats it for and can I move it to somewhere I don't want to build :D
Am I likely to get the answer to any of these questions without resorting to digging the drive up
thanks for any assistance offered
JS
Surface water drain to soakaway?
Thanks, so its effectively a plug hole, even though its 3/4 the way up a sloped drive with a concrete cover and no means of surface water draining to it ?
Are you sure that middle bit at the bottom isn't a second lid?
I've seen some chambers like that with a smaller lid covering a Y junction.
Hmmmm. Could be. I can't actually reach it. Feels solid under a 'prod'
Try some pliers on the smaller circle that's just below the water. Give it a tug and a wiggle ;)
Me too, I would have assumed that It was a rodding eye cover.
Look on the back of the cover - it might give a name and or serial number.
If you dry out the water at the base maybe more will be revealed?
Following a line from the internal stack down to the roadway - is there a manhole cover?
Its obviously been installed with the block paving - whoever did the paving would have knowledge of such a thing.
Or perhaps enquire at the pavingexpert.com site?
If your house was older i would say it was a Buchan trap? It could be an interceptor of some sort due to a back drop or sudden change in the height if the drain run.
Not sure I can reach, but will give it a go
No man hole in the road, although a couple of neighbours have them as well as similar looking ones to mine
The paving has been down for at least 15 years. Before my time. I'll mosey over to paving expert and have a mooch, ta
No idea , but Google will know .
Ta muchly gents
If no manhole is visible then the paving has possibly covered the existing manhole cover.
In an emergency you will needthe manhole for rodding etc. You would do well to locate it.
Perhaps the manhole is this possible rodding eye that was plugged for the original new build water seal test by BCO.
See what the neighbours have to say about their "rodding eyes"?
Do any neighbour's have actual manhole covers in view? If so, where are they located?
My money's on that is a mini chamber on the run from your property to the main sewer, to allow access to your drain. Once that lateral from your property joins the main sewer, access to that run would be available from the chambers on the neighbouring properties either side.
Look familiar?
My PM job, investigating water in a cellar and they have the same inspection chamber, minus the extra lid/cap.
Sorry about the pile of turds ;)
Interior IC's should have sealed covers if they run to a mains connection.
That is what I was expecting to see. But it's not. There is no visible flow when I flush, not even a ripple
Reached in with pliers to grab the 'pipe'in the middle of the puddle. But it's not shifting
Wondering if the only way I am going to find out is to dig the drive up and follow the pipework
