Install a water softener.....
27 Feb 2007
Berkshire
I have a plumbing company and mainly concentrate on bathroom and kitchen isntallations. A customer has approached me looking to install a water softener, now I have seen these devices being installed but have never touched one myself. Can I kindly ask, how do you establish which softener type suits your home, and is the plumbing aspect of installation fairly straight forward?
thank you in advance
sizes vary with amount of water used per day. They are usually estimated by number of people per household. The bigger ones have a bigger salt bin so need topping up less often. Some have a time clock to trigger the flushing, some use a meter. the meters are better.
They are almost exactly as easy or difficult to fit as a washing machine. They are heavy when full of salt and water.
It must be placed in a position where you can easily access it and tip a 25kg sack of salt pellets into it (so preferably not under the sink or in the loft). You might put one in the corner of a run of kitchen units if you can lift or hinge up the worktop above it, and get full access for cleaning and servicing.
It should be placed on a plastic surface (e.g. vinyl flooring) as the spilled and splashed salt will attack most building materials especially metals.
aaaah mr JohnD, was just reading a previous post of yours
Sounds like you know a bit about water softeners. Funny enough, I get on really well with a JohnD on the electrics forum and he always helps me out when necessary... :lol:
I have yet to ascertain the precise facts relating to this installation. But a little information now would be a little heads up for me. For a typical un-vented pressurised system with no water tank but a combi boiler system, supplying a 3 bedroom property consisting of 2 bathrooms for example, with a family of 5, would this model suffice: Kinetico 2020c http://www.kindwater.co.uk/wsproducts.htm
I wouldn't like to be involved too much with electrics here and this model seems to suit my needs as all that is required is blocks of salt.
As a guide, can you advise which model would suit the above if the kinetico doesn't. And for minimal requirements, i.e. if it turns out that the property is a 1 bedroom flat, with 2 occupants, which model would work?
Thanks John
