'We', as in you and the electrician, can't get the box to communicate with the boiler?we can't seen to get the control box to communicate to the boiler
that is your problem remove the red link in 24v switching and put the wires in there not the ebusAnd that is connected to the Ebus
perhaps you need a new electrician!![]()
Yes, the connections from "Com" - common and "NO" - Normally Open, connect to the 24V/RT connections on the boiler.So the 2 wires from con & No go into the 24v switching not the ebus ?
...and a lot of the default setups have both bands sharing the same SSID - that's where many problems startyou can only use the 2.4GHZ setup the default is usually the 5.0 GHZ
