Installation in gents toilets at student pub/restaraunt 2
12 Jan 2006
Now the valve attached to the pipe above the urinal that opens to let water through has had the flex pulled out of it with the L & N cores exposed and when I go near it the light on the sensor flashes so there is probably exposed live cores. What if someone touches them or the wires touch the metal pipe :shock: :shock:
Should I report it? been like this for weeks.
What do you think? How will you feel if you don't and someone gets killed by it?
I'd report it to my local authority EHO if I was in your place.
(BTW - did you intend to start a new thread? Mods - perhaps you'd merge with the original?)
Yup, most that are fitted are done by plumbers - and they tend to fit battery operate ones.
Even the mains versions are only mains in the sensor part, and switch an ELV source to the valve.
