- Joined
- 5 Dec 2007
- Messages
- 2
- Reaction score
- 0
- Country
Hope someone can help me here. We have a vertical installed IMA MPV radiator. This is a six panel radiator and the centre four panels do not heat up - whereas the two outside ones do.
When you are installing it there is a need to effectively "burst" the correct seal internal to the radiator - as it can be mounted vertically or horizontally - to ensure the water flows through the whole radiator dependent upon water inlet/outlet used.
There are four connection points for in/out water and ours in installed using the bottom two.
My question is simple - does anyone have the installation sheet or knowledge to let me know which internal seals to "burst" to allow water to flow through the radiator.
I am tempted just to open all of them and burst anything inside, but if someone knows the right ones it would be better.
Here's hoping someone knows.
