I've just bought a new Smeg single built in 3kw oven and it came with a cable attached but no plug so I've attached a standard 13amp plug to it as recommended in the manual. 3000/240=12.5 so I assume it will be ok.
This existing oven is hard wired direct to a dedicated socket on the wall above the gas hob.
My question is can I remove the cable from the old oven and simply attached a 13amp socket to it.?
Thanks.
Thanks.
