Thank you for your advice, I did wonder if a hob could be operated from the same connection. but didn't know there was a splitter to do the job.
The oven will be approx. 3 mtrs away on a different wall. If I use a splitter can I sink the same size cable in the wall and the new oven?
If you use the same size cable as the existing cooker supply cable, you avoid discussions about whether you need to fuse down at the point where the cable size is reduced. Then at the oven you use the cable supplied if it has a plug, and it's either fused down by its plug, or by an FCU if you use that. Again a matter of taste, if the oven comes with a plug. If one considers the oven as not being able to take an over-current then a fuse is optional.
