I want to replace an old window with a double glazed unit which is wider. The existing window is approximately 1m wide and the new one will be approx 1.5m wide. The old Lintel, which I believe to be a cavity type, will have to be replaced with a larger one, I presume. Does anyone have any ideas as to how to go about this. The wall is cavity (brick and block) and is load bearing.
