Newbie first post, so go gentle!
I would appreciate any comments/advice.
I am about to embark on the installation of a personnel door into the side wall of my detached garage and wanted to check my approach was sensible.
It’s a mid 90’s construction – single skin brick with brick columns each corner and half way along the side wall to support the pitched roof. Roof timbers run parallel to the wall in question and are supported on the end walls i.e. not the wall I want to make an opening in.
Proposed door position is approx. 80cm from the corner column on the side wall and will sit on the top of two rows of blue engineering bricks which correspond to the dpc level on house adjacent.
My plan is as follows:-
Remove a course of mortar on the inside face above proposed door level.
Install a steel L-shaped lintel, with overlap of 150cm each side of the proposed opening width. Bed on fresh mortar and attach to the inside face of bricks as well. The lintel is supporting about 10 rows of single brick masonry above it, so was going to get advice from a supplier on the appropriate sizing/loads. Is this feasible without propping/supporting the wall in any way?
Once lintel is fixed and set attach wooden battens to the outside wall to guide cutter and cut opening neatly below to the upvc door frame size.
Then install upvc door, with the frame width being sufficient to covering any cuts through bricks which expose holes in centres.
Am I on the right lines here?
