- Joined
- 24 Mar 2016
- Messages
- 2
- Reaction score
- 0
- Country
I'm attempting to install a 3rd gen Nest thermostat in place of my old timer.
Essentially for the Nest system there are two units to install, one is the 'Heat Link' which is rather like the old programmer without any display or buttons. The second unit is the thermostat which has a display and a dual and button for setup/operation etc.
My heating system is a Worcester Greenstar Ri boiler downstairs in the kitchen and a H.W. tank in an upstairs cupboard where there is a junction box of wiring for the heating system.
I have a few main questions.
- Is MY WIRING SYSTEM a standard S-Plan?
- Where do you install the Heat Link? I'm guessing it goes where the old programmer currently is, in my case in the kitchen by the boiler. At this location there is a main 240v supply and this is where the live switching to C.H or H.W. is made. However some installs I have seen place it by the H.W. tank.
- The Thermostat just needs two wires to supply 12v which comes from the Heat Link, simple enough, However to mount the Nest thermostat in the same place as the existing one I can't run any new wires (without huge hassle). As there are already mains running to the existing thermostat, which are no longer required, I was thinking of re-purposing them to supply the 12v. Unfortunately these wires go back to the box by the HW tank upstairs and not where I believe the Heat Link should be installed.
