I came to install a new light fitting yesterday, in place of a pendant light fitting.
I removed the pendant fitting, and foolishly did not label any of the cables as I believed I knew what to do. Now the light does not work and nor do two other lights which I presume are fed off this light, although have separate switches.
I have four cables coming into the fitting, one of which I understand to be the switch cable (it has red tape around the black wire). I connected the switch cable to one terminal, all of the neutral cables to another, all the live cables to another and the earth to their own block.
I connected the light fitting's live cable to the switched block, and the earth and neutral to the respective blocks.
The new fitting did not work and now the other two lights are not working.
Can anyone tell me where I have gone wrong?
