Installing AG6 BellBox to Accenta Mini G4 Alarm
19 Nov 2016
I am currently installing an Intellisense AG6 bellbox to a Honeywell Accenta Mini G4 system.
I just want to double check the wiring of the bellbox.
On the Alarm control panel is have the connections:
BELL -
BELL +
STROBE -
SCB T
SCB A
On the Bell Box I have:
ST -
R -
SW -
V +
V -
How should I connect these please?
Many thanks
Bell + =V+
Bell - = SW-
STROBE - = ST-
SCB T = R-
SCB A = V-
Hi again,
I have wired up the bell box now exactly as you suggested.
Sorry but I now have another question.
When I power on the alarm system. 3 of my PIRs are powered on, but 1 has not power / light and is not working.
But they are all wired the same way and all the connections on both ends seem fine.
Also, during walk test 2 of the PIRs are constantly activating (showing as 1) even in an empty room.
I had one of my PIR not working then when i checked I had changed the wires on this one thinking it was the same as the others. I hope you get it sorted.
Hey,
Thanks, all of my PIRs are the same make/model and have all been wired the same way. However, i will double check everything again in case i've done something daft!!
If you have a meter check the voltage at the pir.
You could have a break in the cable so I would check continuity of the cable.
