A bit of intro to my situation:
I want to replace my current (old) analogue thermostat with something better and more precise. At the moment if temp. is set to 22 degrees room can get as hot as 28 or more before it shuts off. I usually dial it down to 15 for it to shut off - and then it won't turn back on until it gets very cold. Needless to say it's hardwired near the boiler on a wall right of the exit door to my apartment. So I suspect the combination of it being up a colder wall + being out of the living room across in the hallway (even though there are no doors between) + the fact that these old things probably have a precision of at most 3 degrees (and I've read it can be as bad as 8 degrees) - is what makes it work terrible.
The actual questions:
Q1: How do I install the RT500RF considering this is how it's currently wired (3 wires installation):
Where (according to manual):
1 = Live [called phase here] (R)
2 = Boiler output [don't know what this is, i presume it's the vital wire, would love an explanation] (???)
3 = Neutral [called zero here] (N)
(in a youtube video for the RT500RF there was a mention of linking the Live and Common in the receiver, but it's not mentioned anywhere in the manual - so I am beyond confused up to this point)
Q2: If I turn the receiver of the RT500RF does it mean that my boiler will be constantly off (it's something I like doing with the current thermostat which has an off switch - turning it off when I go out).
Q3: By installing the wireless (main) on the wall behind my sofa and by using this digital thermostat - I should greatly improve the precision of the system and it should (in theory) go off if temperature goes just a degree over the set temperature, and on if it goes under it, correct?
Thank you so much if you take the time to help me out, I would be greatly indebted.
