L
leeweedon
Hi.
I'm planning on boarding my loft and need a little advice.
The loft is 5.7m by 7m and is split in to 3 sections by two 'main joists' they are 2.4m apart.
Due to heavy lagging I can't see any of the cross/ceiling joists.
My plan, was to buy 2.4m x 89mm x 38mm timber and lay it across the two main joists with 30 cm gaps between each piece of timber.
Once this is complete, lay T+G boarding across the laid boards.
My questions are
1) Is the 2.4m timber going to need support between the two main joists? (i.e will it snap in the middle of walked on?)
2) Is the gap between board to big or small? Obviously the bigger the gap the less board and cheaper the cost.
3) Are there any hidden pit falls I'm overlooking?
Any help or advice would be superb, even if it's "You idiot you've got it all wrong!"
Many thanks
Lee
My questions are
Many thanks
Lee
