    Dismiss Notice
installing galaxy keypad
Discussion in 'Alarms, CCTV & Telephones' started by Jeramy, 3 Sep 2020.
  1. Jeramy
    Jeramy
    1 Oct 2019
    21
    Thanks Received:
    Country:
    Hi, I have a galaxy flex which I'm trying to install myself!!! It says in manual that needs a 680ohm end of line resistor on the end of the bus. Then later on it shows a sketch that i need two resistors. One at the panel this time and one at EOL.
    Q.1 Do I need to put 2 resistors only if I have multiple devices on the bus otherwise is one sufficient?
    Q.2 I have seen videos stating the resistor can go on either + or - as it will do the same job is this correct?
  2. Jeramy
    Jeramy
    1 Oct 2019
    21
    Thanks Received:
    Country:
    Ok, I have connected one keypad and put resistor across A B on keypad and A B on panel and everything seems to be working. But still don't know if i need them both.
  3. Sponsored Links
  4. GalaxyGuy
    GalaxyGuy
    7 Jan 2014
    817
    Thanks Received:
    133
    Fife
    Country:
    The panel has the 680R built-in. When the jumper (next to the keypad connector) is fitted, the resistor is connected. If the jumper is removed, the resistor is not. Normally, you only remove the jumper if you fit two bus lines and the panel is in the middle, with a resistor at each end device on the bus.
  5. Jeramy
    Jeramy
    1 Oct 2019
    21
    Thanks Received:
    Country:
    Thanks for your help
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
