the ones i have seen have 3 connections, obviously L N and EARTH and the Live goes into the thermostat and at the other end another wire comes out and is attached (pre-attatached) to a metal pole. The N and Earth connections are on the heater but do not seem actually connected directly to the thermostat!!
the flat surface shouldn't be to bad as you have a gasket in the middle.
you can try some heat, but then you'll have to wait for it to cool if it don't move.
sounds like you have only cut a small section.
don't matter is you cut it in half it will take the pressure off the thread.
What are you blithering on about?on a serious note though won't it be against water regulations - could contaminate the water!!!!
don't use pfe tape use silicone grease around the boss threads.
softus: i was just curious!!
hoorah! done it it have come off.....Thank you guys ...PS Seco good photos! Not for getting the new heater in place ...apart from the gasket i should use PET tape only right?
