Ah - how easy it is to say "individual RCBOs are the way to go"...
Assuming you can't get a DP busbar then you've got no choice for the neutral feed to each one except cables from a N bar in the CU.
But what would be your preference for the line supply when installing 2-module DP ones - cut off every other bus-bar prong, or use distribution block(s) and a cable to each one?
