Back Up Generators and PV?
Completed a quote for Solar PV installation on a farm, problem is there is an Automatic Back Up Generator that kicks in if the Grid fails, concern is: If the Grid fails and the Generator kicks in and is supplying the house with power at say 1kw, the PV is say Generating 4kw where does the other 3kw go?
Will it damage the Generator?
Is there any sort of protection i can put in to stop any damage?
The Grid comes into an outhouse where the Generator is situated, this feeds the farmhouse via a SWA cable to consumer unit in house. I was going to feed the PV from the Inverter into the consumer unit in the farmhouse to avoid running another SWA cable back to the outhouse. Obviously the original SWA cable shares the Grid voltage/Back Up Generator.
Any advice would be much appreciated
Jim
Jim
