Hi, I have a room which is a conversion of an old garage. The concrete floor is about 2" lower at one end. I already tried using self-levelling compound but this ended up cracking. Ive taken that all up now so im back to the original gradient. What my current thinking is to batton the floor at 40cm intervals with 2x1 battons. At the higher ends i was thinking of using a SDS drill to dig channels to sink the battons into. These could be levelled in their channels using a sand/cement hard mix and fastened using the concrete self tapping screws. Obviously as a head down the gradient of the floor suface my batton height will need to increase but still applied to a level suface. Once battoned i would lay 18mm plywood sheets and fasten. This would give me a level sub-floor.
In the end I want to lay a floating floor consisting of fibre-boards for sound insulation and solid oak over it. this ive done before!
Can anyone tell me if ive missed something in creating a level floor surface or if there is a better/more-efficient way of doing it - im all ears.
