Insulating a shed
15 Feb 2016
Hi All,
We have a shed, just a standard 6x8 pre-made thing but we want to try and stop the drill etc from getting condensation on them over the winter.
Is a breathable membrane stuck around the inside going to be enough to stop this from happening?
15 Nov 2005
Crossgates, Europe
Cook Islands
Hi All,
Does it have a concrete floor with no dpm, constantly wicking up moisture from the ground?
15 Feb 2016
No it's just sat on a wooden base on the grass, we will insulate the floor too if it will have an effect
JP_
17 May 2012
The easiest way is probably to stick insulation boards to the walls, roof and door, and maybe one of the floor too with chipboard over the top, and then add a good old British tube heater as Motman suggested. Although, maybe cheaper to move the tools into the loft for winter? Harder for thieves to nick too! I keep most of my tools in the house these days, including sledge hammer and breaking bars.
15 Nov 2005
Crossgates, Europe
Cook Islands
on the grass,
damp will be coming up from below. as well as encouraging the wood to rot, the water vapour will enter the shed.
If you can lift it and rest the bearers on, say, paving slabs with a ventilated gap, this will help.
JP_
17 May 2012
oooh, just on grass? In that case I'd suggest removing the grass, compacting soil a bit and put some weed barrier down, and use a plastic shed base.
I had this for my previous house, no condensation issues in that shed.
15 Feb 2016
Great stuff thanks guys, sounds easier to bring everything in :)
When I say on the grass it does have stakes at each corner and raised slightly on blocks to make the shed level. However I was hoping just using the membrane would do the trick but if it won't then I should just keep anything I don't want to bin in the house.
JP_
17 May 2012
yep, that's the easiest and cheapest way!
Although, if the shed is currently in good condition, it would make sense to keep it dry. Shed's aren't cheap!
