    Dismiss Notice
Insulating a Single skin external wall
Discussion in 'Building' started by J_N30, 20 Nov 2016.
  1. J_N30
    J_N30
    12 Jul 2008
    557
    Thanks Received:
    13
    Wiltshire
    Country:
    Hi guys.
    I have a single skin external wall backing my stove builders opening.
    I'm getting a fair bit of condensation. Can I insulate it externally?
    Would it be as easy as battening it, Rockwool, then cladding with some flashing on the top edge? (I'm no pro, correct me if I'm wrong!)
    Cheers all.
  2. noseall
    noseall
    2 Feb 2006
    42,235
    Thanks Received:
    2,630
    Staffordshire
    Country:
    Basically you are on the right track. You probably want to include a breather membrane backing before fixing the cladding.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. J_N30
    J_N30
    12 Jul 2008
    557
    Thanks Received:
    13
    Wiltshire
    Country:
    Awesome thank you. Regarding the top edge that I'd be flashing, would it be acceptable to simply attach a piece of treated timber at the desired angle for the water to then run down the flashing?
  5. noseall
    noseall
    2 Feb 2006
    42,235
    Thanks Received:
    2,630
    Staffordshire
    Country:
    Fine. Make yourself an overhanging drip though so it casts the water away from the cladded wall. Look at mimicking something like a plastic door sill then dress your lead over this.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
