Insulating external pipe
7 Apr 2010
Down
I have an external pipe which is coated with a plastic outer the pipe is about 0.5 inches diameter it carries oil from our oil tank to the boiler house but its exposed so what pipe lagging would be best to lag the pipe with so it doesnt fall apart in the wet weather?
If the pipe is plastic coated it will be ok unless you have very cold weather minus 20'c then if you are running on diesel it may start waxing but if kerosene should be ok.Bob
