Insulating external wall
1 Oct 2012
Edinburgh
Hi
I'm renovating my bathroom and I'm interested in insulating two exteriors walls. The house was built 1920s and currently the walls are plaster & lath. The bathroom is on the first floor.
The bathroom is quite small and I'd rather keep the loss of internal space to a minimum.
I'm thinking that I could remove the lath & plaster from the two external walls, leaving the brick external wall exposed. I would then fix an insulated plasterboard to this wall, of at least 50mm thickness. To finish, the board would be taped and skimmed.
Am I on the right lines? Can I attach the insulating board by dot & dab method? Should I need to be thinking about leaving a gap between the external wall and the insulating boards? Do I need to use a damp proof membrane or foil covered boards?
Thanks in advance.
Daljit
Yes you are on the right lines. Ensure to use the correct adhesive for the dabbing, and you don't need a damp membrane.
Thanks for responses. I'd never heard of acquapanels before! Also found the link to Historic England given on a related thread v useful.
Cheers
