insulating garage floor
5 Dec 2012
I do sports massage and wok from home. we a re buying a new house that has a single skin detatched garage with concrete slab floor. I am going to stud, insulate, plasterboard walls and ceilings.
The side door to garage is level wiith the garage floor.
I am taking out the metal garage door and replacing with double doors with glass in.
My only concern is that because i plan on insulating the floor (using timber screwed in to floor, celotex slabs and loft boards, folllowed by laminate floor), there will be a step up when you go in to the garage. This means the door will have to open out, but more so it isnt flush.
Is the only way to 'brick up' before installing the door? i would rather an alternative option where i dont need to brick up
Any idea?
Thank you
You can't have a step at a threshold, more so if this is a business premises. The opening will need to be raised.
You'd need to use bricks or equivalent to close the opening up to the dpc anyway, then fill in the floor void with a dpc if the garage didn't have one, then insulation and timber . So a door can open in if wanted
But as this will be a business, don't you need to be DDA compliant?
