Insulating roof internally
Discussion in 'Roofing and Guttering' started by Jack07, 28 Nov 2021.
  1. Jack07
    Jack07
    8 Oct 2011
    109
    Thanks Received:
    Country:
    Hi, I've tried looking to see if this has been asked before but can't see anything posted.
    I have a Welsh slate roof with no felt. It's in good nick and my roofer advised me to leave it as it is but just be vigilant as any damaged slates will need to be fixed immediately.
    I'm in no rush to spend £1,000s on a new roof. Inevitably it will need to be done in the coming years but in the meantime I'm trying to Insulate the house as much as possible.
    Has anyone insulated their roof internally and if so what product did you use? Are there any negative points such as damp problems or lack of breathability?
    Regards J
  2. Sponsored Links
  3. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,747
    Thanks Received:
    1,004
    Durham
    Country:
    Why insulate the roof? Loft insulation is much cheaper and easier.
  4. Jack07
    Jack07
    8 Oct 2011
    109
    Thanks Received:
    Country:
    Hi, I have insulted the loft but being an old stone house it can be very cold. The extra loft roll doesn't seem to make a difference.
    I know it may seem a bit counter productive insulating both but I'm looking at ways to save as much energy as possible.
    If the attic space is warmer surely it would reduce the amount of warmth being pulled out of the house?
    Obviously the lack of felt really allows the wind to blow through up there. Hoping its not just the warmth but reducing the draught would help?
  5. datarebal
    datarebal
    1 May 2007
    3,440
    Thanks Received:
    707
    Hampshire
    Country:
    Air flow is good for the structure.
    How much fluff do you have at ceiling level ?
  6. RonnyRaygun
    RonnyRaygun
    4 Apr 2008
    1,873
    Thanks Received:
    261
    Hertfordshire
    Country:
    I think you’d be better adding more insulation at loft floor level. No point trapping heat in the loft where no-one ever goes, much better to trap it in the bedrooms.
    Obviously additional insulation at loft floor level becomes an issue if you use the loft for storage. You might need to use some stilts to raise the floor level before boarding out.
  7. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,747
    Thanks Received:
    1,004
    Durham
    Country:
    As both comments above. Your roof is in good nick partly because of the draughts- keeps the timbers dry. You are correct in one sense- the greater the temperature differential across a thermally porous barrier, the more energy per hour is lost, but it's a linear effect no exponential, the most cost-effective way to keep the heat in the bedrooms is the current standard 300mm loft insulation (if you have laid new on top of old you might want to lift the new and check the old to see how much it has crushed down over the years, older glass wool did tend to sink & lose effectiveness).
    Make sure you leave an air gap at the eaves (if you want to max your insulation and eaves are at joist height, tack bits of breathable membrane across the rafters at eaves height, you can then insulate the edges of the ceilings without risking blocking the eaves).
    Make sure any pipes, cables etc. going into the loft are well sealed. Make sure your loft hatch is well sealed, ideally insulate over it (have the Rockwool overlap the hatch for more draught reduction).
    EDIT If you have any active water tanks in the loft, consider boxing them in then insulating the outside of the boxing (and leave a gap in the loft insulation under the tanks)
    Any open fireplaces not in use- ideally cap the flues, block the fireplaces (but leave a louvre vent in the fireplace so you don't get condensation in the flue). If the fireplaces are used occasionally for a real fire, get one of those chimney sheep things.
    Once you've done that lot, have a look at your radiators and heating system (I'm assuming central heating here)- are they sized correctly for the rooms and the boiler (modern boilers run most efficiently at lower output temp so you need larger rads to get the same kWh out of them.
    Windows.
    Doors.
    Carpets.
  8. Sponsored Links
  9. Jack07
    Jack07
    8 Oct 2011
    109
    Thanks Received:
    Country:
    Many thanks for all the responses.
    The loft has 2x100mm which was already installed before I bought the house. Both layers look good.
    I have been up there running a new bathroom extract and was thinking of ways to limit heat loss. I'm going to buy some extra top-up rolls and lay over this week. The space isn't used for storage so I am thinking of maybe getting another 200mm.
    I also have a gas log effect fire which is awaiting a service to get up and running. This runs up the solid stone wall so it has previously helped retain the warmth in the wall.
    Thanks again
  10. Mr Chibs
    Mr Chibs
    28 Jul 2015
    1,097
    Thanks Received:
    182
    Country:
    Thought the recommended thickness for loft insulation is a shade under 300mm.
    like others have said, just beef up loft not the roof.
  11. Notch7
    Notch7
    15 Sep 2017
    26,104
    Thanks Received:
    1,824
    S. Uplands
    Country:
    seal and insulate the loft hatch
    be careful at the eves -insulate the loft floor but dont block eves ventilation
    think carefully about your water tank if its in the loft -you dont want it freezing
  12. catlad
    catlad
    29 Jul 2011
    4,989
    Thanks Received:
    759
    Lancashire
    Country:
    Overboard the bedrooms ceillings with insulated plasterboard.
  13. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,747
    Thanks Received:
    1,004
    Durham
    Country:
    You get into diminishing returns with insulation thickness. If you want to stick a total of 400mm up there crack on, you won't get 1/3 better heat retention than with 300mm & rockwool price is pretty much by the cubic metre so an 100mm roll will generally cover twice the area that the same manufacturers' 200mm roll will do.
Loading...
Share This Page
