    Dismiss Notice
Slate roof gutter between neighbours
Discussion in 'Roofing and Guttering' started by Alan51, 25 Nov 2020.
Tags:
  1. Alan51
    Alan51
    13 Oct 2020
    30
    Thanks Received:
    Country:
    Got a quote for my roof to be refelted with breathable felt, new battens and the original slates reattached with recon slates where needed. Needed as no ventilation to the roof space and numerous slates have slipped.
    My slates are a completly different size to the neighbours and the tie in is terrible so roofer has said that the slates will need to be cut and a gutter will be needed between the houses as the slates can't be tied in successfully due to the different sizes. I can see his reasoning but does it sound correct to more knowledgeable people.
  2. Sponsored Links
  3. mattylad
    mattylad
    27 Apr 2008
    8,185
    Thanks Received:
    620
    Country:
    Do you not currently have a gutter?
    A photo would help understand the situation better.
  4. Alan51
    Alan51
    13 Oct 2020
    30
    Thanks Received:
    Country:
    I'd struggle to get a photo as it's on the roof. The problem is the slates on my roof are a different size to the neighbours so the tie-in is a mismatch of overlapping slates. The roofers solution is cut a line through the slate along the party wall from the chimney down to the gutter and have a channel that would catch any water. So my slates would stop and the neighbours would start, they wouldn't overlap each other.
  5. datarebal
    datarebal
    1 May 2007
    3,335
    Thanks Received:
    682
    Hampshire
    Country:
    That is perfectly ok. If done properly
    • Thanks Thanks x 1
  6. Alan51
    Alan51
    13 Oct 2020
    30
    Thanks Received:
    Country:
    'If done properly' there is the age old problem.
    I'm hoping this should be done properly as the roofer has done a lot of work in the area and has a good reputation.
    I might just be being nervous as this is a lot of money for me to spend.
  7. datarebal
    datarebal
    1 May 2007
    3,335
    Thanks Received:
    682
    Hampshire
    Country:
    If he is known locally then it should be fine.. it's not difficult
    • Thanks Thanks x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
