- Joined
- 4 Jan 2025
- Messages
- 2
- Reaction score
- 0
- Country
Hi
First timer on the forum. I'm sure this question has probably been asked before - but I couldn't find it anywhere.
Im building a standard single storey extension and all of the specs / drawings I can find online - show a typical construction of
12.5mm Plasterboard
40mm Celotex TB4000 over studs
Vapour Control Layer
100 x 50 mm stud wall with 90mm Celotex GA4000 between studs
12mm Plywood Sheathing
Breathable Membrane
50mm Cavity
Brick Cladding
Is there any reason why I can't move the extra layer of insulation outside of the studs (between the ply sheathing and the studs) - as it would give me a much more useful 10mm gap for dropping down wires etc behind the plasterboard...
12.5mm Plasterboard
12mm Plywood Sheathing over Insulation
Breathable Membrane
50mm Cavity
Brick Cladding
12.5mm Plasterboard
Breathable Membrane
50mm Cavity
Brick Cladding
12.5mm Plasterboard
Breathable Membrane
50mm Cavity
Brick Cladding
