To All!!
Our timber frame company sent 6 different types of insulation for the new dormer bungalow we've just built. I think i know where each of the different types go, but would like to have a second opinion!!
The insulation types are:
1/ 140mm thick Fibreglass Batts
2/ 90mm thick Fibreglass Batts
3/ 100mm thick Fibreglass Rolls
4/ 170mm thick Fibreglass Rolls
5/ 100mm Kingspan
6/ 40mm Kingspan
The 140mm batts are for the external walls, the 90mm batts are for the internal walls (for sound insulation). The 100mm Rolls go between the trusses, and the 170mm goes on top of the 100mm in a perpendicular direction.
There is enough 100mm Fibreglass roll to go inbetween the 1st floor joists, would this be correct?
And finally the kingspan im presuming is for between rafters between the ceiling tie and the external wall? (remember, dormer bungalow).
The reason im confused is because they have sent 40mm and 100mm kinspan to fill the 6" rafter space - why not send 1 sheet of the correct thickness so i dont have to double cut and double fit?!!
Any ideas would be gratefully received!!
Peterb
5/ 100mm Kingspan
6/ 40mm Kingspan
Peterb
