Good evening.
Basics- require insulation for single wall construction with stud wall in a bathroom. Do i work from the inside (boards) or from the outside (inject) ?.
If your not too bored already the details follow .
May i first start by saying how staggeringly ignorant i appear to be about this topic. Two hours ago i started reading this forum for hints and tips on a diy solution to the above. Now that i have started to remove my head from the dark place i am terrified and confused with the myriad of suggestions.
I have a circa 1900 terraced hse, with circa 1930 extension to the rear which contains the bathroom/utility room. When i purchased this house 16 years ago it was a requirement to have a cavity wall in this extension (stud wall). At the time the builder asked if i wanted insulation, being STUPID , young and poor i said no. Now as each winter goes by and i get older i feel the cold more.
So what can i do to improve this ?
Extension is split into two, bathroom 3m x 1.4m (two sides external and two windows) utility has about 1m external wall (with large window). Concrete floor. Window sill (?) has a 250mm depth (not sure what size that would make the cavity ) The bathroom is ground floor with a felt roof (guessing that requires insulation as well ).
