Base for stud wall in garage
21 Oct 2014
West Midlands
I have skirted around this before, but was after some concise info on how to fashion a suitable base for a stud wall in my garage that will form a utility room. The extension has had proper foundations cast. That will be block walls. For the utility room which will occupy part of the garage, I was considering single skin blocking up approx 300mm so I could continue my concrete floor slab (100mm MOT, sand blinding, 100mm ins, 100mm concrete) from the kitchen extension, then build a stud wall off this.
My issue is as follows. The main extension is a double skinned block cavity wall - all standard. With space being at a premium in the garage, I was considering a plasterboard stud wall with a 100mm full filled cavity.
Would this meet regs?
How do I avoid the thermal gap between the bottom of the wall insulation and the floor insulation?
What foundations do I need for this? Thick lintel bedded on the concrete garage floor? Thin strip foundation? How deep?
140mm single skin block?
Thoughts welcome
2 Feb 2006
Staffordshire
You typically build a small masonry sleeper wall straight off the slab up to DPC. Lay polythene DPM into the floor trough and construct your floor as normal, i.e. insulation plus perimeter insulation then screed. You then lay a DPC on top of the bricks and then build your stud wall off this. You would need say 100mm Celotex between studs and then another 50mm across. I'd prefer the 50mm across the studs to be on the outside. Vapour barrier, plasterboard and skim.
21 Oct 2014
West Midlands
Thanks - good info. That's a lot of insulation. Is it all needed for BC? I suppose in standard construction block and cavity walls the blocks offer some insulation. In this case it's just insulation and plasterboard.
