- Joined
- 4 Jun 2022
- Messages
- 1
- Reaction score
- 0
- Country
Hi, currently renovating my bathroom and need some advice on insulation inside a new stud wall…..
In order to improve pipe routing and also to provide some recessed wall storage in the shower I have built a stud wall around 120mm off of the existing, external blockwork wall. The stud wall will be boarded with tile backer board and tanked. This external wall is a breeze block/brick construction with cavity insulation in between.
For the existing, studwork internal walls I plan to put rockwall sound insulation in them before re-boarding with the tile backer board but wondered for the new external wall studwork if it would be better to apply rockwall thermal insulation or even if extra insulation in addition to the existing cavity wall insulation is a good idea at all? As mentioned above, the wall will form part of the shower area so do not want condensation to become an issue in the stud wall cavity.
