Dear all,
I am planning to convert my integral garage which currently has a concrete slab sitting approx 150mm below the interior floor level - no damp proof membrane, no insulation.
The rear of the garage is connected to the kitchen and has a side external door too; it is used as utility space - washer, drier, additional fridge and freezer etc. The front of the garage has the 'up and over' garage door off the drive, and is used only for storage.
I want to convert the front half into a secluded additional study room, but leave the rear half as the utility space unconverted. I intend for the converted front half to meet building regulations for a converted room.
The necessary insulation of the floor of the converted front room will necessitate that the floor is raised to the same level as the kitchen - 150mm above the unconverted rear half of the garage. The result would be a 150mm step down into the utility from the kitchen, followed by a 150mm step up into the converted study room.
Does anybody know of any building regulations this would contravene, or any complications that would prevent this solution?
All responses will be hugely appreciated, and I thank you for any in advance.
