Build up floor
12 Sep 2008
Cheshire
I have an attached garage that I want to convert part of into a utility room. The garage floor is 170mm lower than the rest of the ground floor and I need to build this up level.
The garage was a 2008 extension before we bought the house so it's already insulated and has a DPM.
Would if be possible to build up the floor on 150mm joists sat on the existing concrete and 18mm ply/chipboard?
Many thanks
Alan
2 Feb 2006
Staffordshire
What leads you to believe it is insulated?
A typical floor spec like this would be to lay 100mm celotex insulation then apply a 70mm screed.
You can go with timber and ply/chipboard if you wish but you will have the added headache of venting the floor void.
12 Sep 2008
Cheshire
We've got the original passed plans from building regs showing the make up. Obviously that assumes that is what actually happens but you can see evidence of DPM at door opening do fairly confident.
Noted regarding vent - this should be easy to achieve as there are two exposed internal wall sections that could be vented into but noted re celotex and screed option.
1 Dec 2008
Devon
But if the void is filled with insulation...there is then no airspace where condensation/damp can build up... and no need to ventilate it?
25 Nov 2014
London
According to me, you will not be having any problem converting garage into utility room. I guess you should go ahead with this modification without any worry.
