    Dismiss Notice
Integrated dishwasher door sticking on the kick plate
Discussion in 'Appliances' started by molko, 8 Mar 2012.
  1. molko
    molko
    7 Jan 2006
    38
    Thanks Received:
    Manchester
    Country:
    Hi
    As per title really. We have an Siemen dishwasher, its fully integrated into the worktop.
    Recently we've noticed that when we open the dishwasher door the bottom of it catches on the kickplate below.
    This has gradually got worse, to the point where when we open the door it now drags the whole dishwasher out !.
    I cant really undestand how this can happen, or how I can fix it....any ideas ?
  2. molko
    molko
    7 Jan 2006
    38
    Thanks Received:
    Manchester
    Country:
    To note, I can see the kickplate has been cut into to allow for the opening of the dishwasher door - and it used to open fine.
  3. molko
    molko
    7 Jan 2006
    38
    Thanks Received:
    Manchester
    Country:
    \____________________/ sort of that shape removed from the kickplate
  4. captaincaveman1
    captaincaveman1
    30 Nov 2011
    907
    Thanks Received:
    63
    Merseyside
    Country:
    Poor fitting by the installer defo no fault of the appliance you need to remove kick board and see how the installer has raised the dishwasher up to the worktop . The dodgy fitters use little offcuts of wood which eventually give way.
  5. molko
    molko
    7 Jan 2006
    38
    Thanks Received:
    Manchester
    Country:
    Hi thanks for the reply, sounds about right we have loads of "niggles" in this house.
    What is the recommended way to raise the dishwasher ?
  6. captaincaveman1
    captaincaveman1
    30 Nov 2011
    907
    Thanks Received:
    63
    Merseyside
    Country:
    the best way to sit it is on solid piece of old worktop cut to the size of the base of the dishwasher that way it will never drop and if need to remove it for servicing then it will pull out easily and it wont get snagged on any flooring
  7. foxhole
    foxhole
    14 Mar 2006
    15,497
    Thanks Received:
    1,698
    Kent
    Country:
    Should have adjustable legs, don't sit on worktop totally unsuitable, will swell and distort when wet.The kickboard was probably not sealed and has buckles upward when wet.If the machine moves when door is opened then it was not secured to worktop as per fitting instructions.
  8. captaincaveman1
    captaincaveman1
    30 Nov 2011
    907
    Thanks Received:
    63
    Merseyside
    Country:
    Yes it has adjustable legs so no probelm at all sitting on worktop even it does swell slightly which it wont unless it has a leak !!!!!! :rolleyes:
  9. Sponsored Links
  10. molko
    molko
    7 Jan 2006
    38
    Thanks Received:
    Manchester
    Country:
    Hi
    Just got round to looking at this......That's what Easter breaks are all about :)
    I have taken the kickboard off, and can see the Dishwasher is sitting on a slab of wood (which is fixed to the floor).
    The Dishwasher has a screw that lowers and heightens it. I have adjusted the screw to increase the height of the Dishwasher so that it no longer catches on the kickboards.
    However, the Dishwasher is now no longer flush with the rest of the kitchen cupboards from a 'profile' perspective.
    Seems that increasing the height has pushed the Dishwasher 'out' at the top..
    Any help more that appreciated...
    Thanks (Hope all that makes some kind of sense)
  11. molko
    molko
    7 Jan 2006
    38
    Thanks Received:
    Manchester
    Country:
    Hi
    It looks like that screw at the front of the Dishwasher is only raising the back of the Dishwasher - I guess it should it raise both front and back ?..
  12. assuhors
    assuhors
    13 Jun 2007
    462
    Thanks Received:
    58
    Sussex
    Country:
    The screw in the middle only raises the back single central leg,there are two legs at the front.
    • Thanks Thanks x 1
  13. molko
    molko
    7 Jan 2006
    38
    Thanks Received:
    Manchester
    Country:
    Hi
    Thanks, yes you are correct it only raised the back leg.
    I cannot figure out how to raise the front legs ...I can see the front legs, i've attached two pictures.
    Is there a special tool to raise the front legs ? It looks like there is a very small hole above the actual leg ?
    Thanks for your help[/img]
  14. molko
    molko
    7 Jan 2006
    38
    Thanks Received:
    Manchester
    Country:
    Hi
    Sussed it !! I was turning the legs the wrong way :oops:
    Thanks for all assistance
  15. assuhors
    assuhors
    13 Jun 2007
    462
    Thanks Received:
    58
    Sussex
    Country:
    yeah ,the legs were just screwed all the way in.
    • Thanks Thanks x 1
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
