Someone had done this in my outside loo, where there is an incoming live feed to the switch and the light run from there, but rather than a choc block, they did this:
Common - switched live cable to light fitting (reason why becomes apparent)
L1 - Permanent live supply
L2 - both 2.5mm neutrals filed down to fit in the terminal on the 2 way switch
Good idea until someone who doesn't know what they are doing rewires it (thankfully I did!) - or someone tries changing the bulb when some other connected equipment is dumping a load of juice to neutral through a fault or such like.
Oh, the other thing, thankfully I was fitting it indoors, but don't buy one of the five quid "IP44" bulkhead lights from B&Q and expect it to be ok outside, it's a shonky heap of junk....
