Hi There,
I have Intergas 24/18 boiler and it recently started coming up with error codes 12,13 and was switching itself off. This was suggesting sensor 1 (according to manual) which has been now replaced.
Now though, when the hot water runs for a while and the boiler goes up to program 6 and then drops down to 1 and comes back to 6 again (you can hear the fun working all right all the time) but the boiler is doing some very strange vibrating noise (taking off plane type of noise) which is quite loud and scary. If you close the hot water tap it will stop doing it or if you wait 3-5 seconds it will stop.
It does bother me though as I do not know what's the source of it.
Would appreciate help.
I did open the boiler's cover just to make sure it's the source of the noise and 100% it is the boiler and my thinks it's the vertical plastic pipe (fumes?) that is causing that sound.??
Thanks in advance.
Thanks in advance.
