Hello,
I have an issue with the temperature of the water from the shower.
It warm, verging on hot but not quite as hot as I would like it. I will say at this point that it is perfectly usable. It's just that when I come in from a long cycle in the wet and/or cold it's a few degrees under what I would like it to be.
The system was all installed brand new a couple of months ago.
New 28mm feed from the meter to the house by the boiler. the the cold runs to the boiler and spurs off to the rest of the house on 22mm.
The DHW runs from the boiler to the shower mixer on 22mm and is the first stop so to speak.
The symptoms are that when you turn the mixer past 38 degrees it does not get any hotter. I have unassembled the mixer and re calibrated it to the max it will go, still no noticeable difference in temp.
I think the issue might be with the pressure of the cold feed in to the shower mixer vs the DWH pressure from the boiler. So that the mixer is getting overwhelmed by the cold and can not get any hotter. The DWH on all the taps is scolding!
I have the boiler set to 65 degrees on the DWH, the highest it can go.
I have tried turning on a cold tap with the shower running to see if the reduction in pressure would help. It did seem to a little but the major effect was the flow reduced drastically. Not really what I was looking for!
Does anyone have any suggestions?
I have got the place where I got the shower mixer from the send me another on so I can swap it out and see if the cartridge is duff, but i doubt if it is.
Is there any way to turn the DWH past 65 on the boiler? Or does that introduce other issues?
Regards,
Simpic
Regards,
Simpic
