Intergas combi no heating. (1)
26 Jan 2025
Hi all, I'm a newbie on this site .basically we had a water outage last night and now our central heating doesn't work but we have DHW. I've checked the water pressure 1.5 bar and bled rads and a bit of air in boiler still no joy any suggestions would be appreciated.
Kind regards Brian.
Kind regards Brian.
Did you mess about with your water stop tap?
HI noseall,no haven't touched anything went to bed last night no warning of mains water pipe burst come to clean teeth no water flushed toilet after pee got up this morning water back on ,DHW OK no Central heating boiler pressure is at 1.5 bar small amount of air in rads and boiler I bled those it an Intergas HRE 36/30 Combi boiler.
I'm just wondering if there is any shoite in the system?
I've got no idea, would that not affect the DHW as well? ,everything was working OK last night until the water outage and not being a plumber not sure how ****e would get into the central heating side of things I could understand if it was the DHW side .
Not sure.
All I know is that on the odd occasion where we have pulled on say a soft copper main with the digger, leading to the house, we have had issues with limescale entering the system and blocking fine jets etc. We try and flush out, using an outside tap, these days.
Kind regards Brian.
Have you pressed any buttons on the boiler ? Want controls do you have for your heating
Any fault codes ?
I have the same boiler.
You might want to post as well on the central heating and plumbing discussion board. I have asked for this thread to be moved as well.
I've checked the pressure which is 1.5 bar we a have theNeomitis heating control for the central heating and when prompted for central heating there's just a click but nothing happens even though according to the remote display it depicts a gas flame as thought the heating is on.
Does the screen show the same as my pic ?
Hi all, we've got an Intergas HRE36/30 combi boiler and last night when we went to bed it became apparent we'd had a water outing Stafford and then was no water to taps or toilet cistern just a dribble. On getting up this morning water was back on but now our DCH doesn't work but the DHW does I've checked the pressure and it's 1.5 bar and there was a small amount of air in the bathroom towel rail and boiler which I've bled everything was OK until water outage any ideas please.
Kind regards Brian.
