I just rang Intergas and they say verbally all their combis can be open vented,
I think you are telling porkies Dannyboy. I just rang Intergas and they say verbally all their combis can be open vented, but they will not issue anything in writing. The manual does not state the combis can be open vented. It is a matter of ringing them up then they will verbally confirm if questions are asked. That can just create hassle.
The "difficulty" for any boiler on an open vented system is knowing if there is water in the heat exchanger before deciding to fire up the boiler. If the boiler is restricted to use on non vented systems then a simple pressure sensor will detect lack of ( adequate ) water and prevent the boiler firing onto an empty heat exchanger. If the boiler is "authorised" for use on vented systems then the system to prevent ( prolonged ) firing onto an empty heat exchanger is more complex than a simple pressure sensor.
