- Joined
- 31 Jan 2018
- Messages
- 3
- Reaction score
- 0
- Country
Hello all, first post here so be gentle with me!
I am the (not so) proud owner of an archaic WORCESTER 28CDI combi.
Around Xmas time the boiler made some horrible loud grinding noises and then gave up completely, RGI came round and diagnosed the fan.
Brand new fan fitted and then the boiler immediately started displaying an air flow fault when attempting to use either the HW or CH - it had never shown this fault before. It then seemed to start working ok again that evening.
The following day the air flow fault continued whenever we attempted to use HW or CH, after several power on/off resets it would work.
The original RGI was unavailable so I called out another company after getting it in the lughole from the wife, they checked the fan/venturi was clear - it was, I checked the flue from outside as best I could and it was clear too, they checked the gas valve and set this up according to Worcester specs. This RGI said the APS sounded like it wasn’t working correctly and was chattering so a new APS was ordered and fitted - when he left the boiler was warmed up and working. An hour later the intermittent air flow fault started again.
I got told it might be the PCB and so a refurbished PCB was ordered and fitted, same fault continues!
The boiler seems to work ok once it’s warmed up. It’s not losing pressure and when it is working all rads and water are red hot.
I’m stuck on ideas and fast losing patience and money trying to solve the mystery - if anyone has any ideas it’d be much appreciated, otherwise I’m just going to have to buy a new boiler
Cheers
Gary
Cheers
Gary
