thanks,never gave it a thought. Replaced cat.,4yrs ago, rattling baffles.audi tdi 1,9. originally infrequent but nnow happening on daily basis.Help,please.
Thanks John, should have said that engine starts and stops.Only occurrs when 'car secure ight in tach.clock,flashes.Think it actuates,fuel cut of mech. Have tried 'hot wiring' cut of valve when it plays up---does not have any effect. night mare! can start no prob. 20 times on trot,21st----won't! Thanks for all this assistance----RayWhen you turn the ignition on, can you hear the swish of the fuel pump starting up?
John![]()
suppose anything is poss. Had a recon motor 40.000mls ago.Car gous a dream on the road,no apparent issues,no clatter or any indication other than intermittent starting probs.Failing crankshaft / camshaft position sensor?
Wotan
intermittent faults are the most difficult to find, but if the fault is logged then a diagnostic should find it, may well be good value.suppose anything is poss. Had a recon motor 40.000mls ago.Car gous a dream on the road,no apparent issues,no clatter or any indication other than intermittent starting probs.Failing crankshaft / camshaft position sensor?
Wotan
Do you guys think I should get an audi diagnostic? Many,many thanks for all your help and advice------------Ray
